WOL behind Cisco 1751
How I can remotely switch-on my computer. I am using Cisco 1751 Router. And my computer is behind this Router.
Bronze
Re: WOL behind Cisco 1751
Do you want to login to the computer from remote location or switch-on the pc fromj a remote location?. Clarify your requirement based on your exact request, then I can provide you a more precise reply. Also,give me a brief overview on your network setup.
I want to switch-on the PC from a remote location.
I have small network of 2 PC`s at 2 diffirent locations. At both the places I am using Cisco 1751 routers.
Chopra,
What you need is Wake on LAN.
Here are some guidelines.
http://gsd.di.uminho.pt/jpo/software/wakeonlan/mini-howto/wol-mini-howto-2.html#ss2.1
If I want to switch-on my computer from LAN then it is working fine. But if I want to switch-on from a remote location then somtimes it work and somtimes it does not work.
Is there any way that I can TELNET it from a CISCO Router-1751 (which is before my computer)? So that it can simulate like a local command.
Chopra,
What program are you using to do WOL ? WOL uses UDP broadcasts and if you are on a remote site separated by routers, your router could be blocking this broadcast. I would suggest adding
ip helper-address command on the remote router, as well as add a "ip forward-protocol udp " to forward the appropriate port used by the application.
Hi Shanky
I am using "SOLAR WIND" programme to send magic packets.
I want to know what is "ip helper-address"
You might find this funny..but check this link.
http://www.routergod.com/trinity/
PS: Please rate the post if you find it helpful!
158
