working with qos
Hello guys.
I need understand something... How i can define a priority for a class of traffic? i want that my citrix traffic use more bandwitch and have more priority than other traffics....the mode of how i undestand, the bandwitch and priority commands in policy-map cant help me with this.... or i wrong ?
  • WAN Routing and Switching
working with qos
Yes, priority or bandwidth can, but there's a difference in which one is used. You have to create your class map to match on the citrix traffic:
class Citrix
match protocol citrix
Then you create your policy map:
policy-map Citrix
class Citrix
priority 1024
OR
class Citrix
bandwidth 1024
The differences are that the priority command guarantees and polices at 1024, but the bandwidth command guarantees at 1024 but doesn't police. If there is NO traffic matching any other policies and there is available bandwidth, the priority command can use more than 1024 up to the full bandwidth of the circuit.
Your class map can match on the protocol or acl. I use acls because we only use the web interface, so I tie that in to a destination ip address and port.
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
working with qos
Ok but, in one CISCO note have something like this:
"The bandwidth command defines a behavior, which is a minimum bandwidth guarantee."
this is the document:
http://www.cisco.com/en/US/tech/tk543/tk757/technologies_tech_note09186a0080103eae.shtml
So, if is the minimum, this is not a good options for bandwidth control, right ?
and ok ok, i am a bit confused with QoS, im rly new with this :S
Other question:
If i apply a outbound policy in one interface, one serial interface, i need to apply one policy for the ethernet
interface too ? The ethernet interface will mark the packet for the serial interface ?
working with qos
You can classify/mark on the same interface the policy is on. The "minimum" means a guarantee. If you set bandwidth to be 1024, that's the minimum bandwidth the class will receive meaning it's guaranteeing you'll get that amount and it sets it aside when traffic that matches the class is queued.
You can do a marking on the lan and then match on the wan side, but I've always done it only on the wan side. If you mark on the lan, you would create a class map to match and then set your dscp marking. Then you match that marking on the wan side to set it to queues. It's more work, and I'm not sure it's necessary.
HTH,
John
Hall of Fame Super Blue
working with qos
John
For my own clarification my understanding was that if you mark packets on an outbound policy then you can only use those markings on the next hop device ie. classification happens before marking ?  So if you marked them with an outbound policy those markings would not be available to be used for classifying traffic into queues.
It sounds like that is what you do though so maybe i have misunderstood how it works ?
Jon
Super Bronze
Re: working with qos
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Jon, you're correct, you cannot use marking you set on egress for egress classification (same interface egress).
Jon/Joseph,
I may not have made myself clear on my last post unless I'm not understanding what Joseph is stating. I don't believe you can mark, say set dscp 21, outbound, and then match on that outbound as well. When I said egress, I meant queueing classification, but the marking would be carried to the next hop.
For example,
policy-map Test
class Test
bandwidth 1024
set dscp 21
That would still guarantee 1024 to the class Test, but it would also mark the packet with dscp 21. That's what I meant. Sorry for the confusion!!
Thanks!
John
working with qos
John
No problem, i think it was just a semantic thing rather than any misunderstanding on either part.
Thanks for clarifying.
Jon
working with qos
Leonardo
What this means is that per cent you allocate to the bandwidth is a minimum ie. it can use more than that if there is spare capacity to use but if the interface is congested it will get the per cent you allocated to it.
This is fine because you generally don't want unwasted bandwidth. As John noted the priority queue is policed but packets that are marked for the priority queue can use excess bandwidth but as far as i know if they use any excess bandwidth the packets are not treated as priority packets.
If you apply an outbound policy then yes if you have not marked the packets anywhere else then you would need to mark the packets on an inbound policy on the router. You may be able to mark the packets on a switch which presumably you have. if you do and the switch supports it, it is worth marking the DCSP value as this would not then need to remarked on the router.
Jon
Super Bronze
Disclaimer
Posting
Yes and no.  Class will get the percent allocated if all the class percents sum to 100 and all the classes want more than their allocation.
For example:
policy-map sample
class a
bandwidth percent 25
class b
class c
bandwidth percent 50
If there was no class c traffic, and classes a and b both wanted all the bandwidth, each would get 50%.  If there was no class b traffic, and classes a and c both wanted all the bandwidth, class a would get 1/3 and class c would get 2/3.
The key to understanding bandwidth allocations, whether percentage or absolute, it really sets dequeuing scheduling ratios between the classes, so the above would be 1:1:2
Correct, because LLQ packets are only policed when they actually queue in the LLQ.  When then are not in the LLQ, they are FIFO on the tx-ring (interface hardware queue).
Packets don't need to be ToS marked, unless you're examining the markings for some purpose such as for classification.
In John's first post, he's using NBAR classification, and he mentions ACL classification; both will work just fine without any kind of ToS marking.
The advantage of ToS marking, it's less for the device to examine when doing classification.
As to the merits of marking/trusting as close to the source as possible, that's the "book" answer, but in practice, often QoS isn't critical on LAN and can be real pain to manage on a LAN.  (You can also run into the need to tune buffers if you don't want QoS activation performance to drop in a 2K or 3K switch.)  If you have only a few WAN interfaces, which are likely to congest because of much less bandwidth than the LAN supports, I've found it pretty effective doing an egress policy similar (perhaps with a few more classes) to what John shows in his first posting.
158
