01-08-2014 03:06 AM - edited 03-04-2019 10:01 PM
Hi.
I have a problem with a Cisco switch 2960.
i have made upgrade to a 2960 switch, and something goes wrong. Now on the switch panel only stat led blinks and i cannot acces it,
neither with console. I reset the switch but nothing change.
Please help.
Thank you.
Solved! Go to Solution.
01-09-2014 04:57 AM
If the IOS loaded is wrong then the switch would continuously reboot. (And that is why we are unable to access it)
In this case just press the MODE button so that we may stop continuous reboot of switch and send it to ROMMON mode.
Now, we have two options to recover the switch:
1. If the correct image or the old image is still in flash of switch then boot the switch with that image.
2. If no image is present now in the switch flash then we have to do XMODEM recovery of switch.
Here is a documnent for the XMODEM recovery:
http://www.cisco.com/en/US/products/hw/switches/ps628/products_tech_note09186a0080169696.shtml
Steps are:
1. Open a hyperterminal
2. switch: copy xmodem: flash:
3. From the top of the HyperTerminal window, choose
Transfer > Send File
4.Choose the Xmodem protocol in the Send File dialog box and click Browse in order to select the Cisco IOS image (.bin file) that you downloaded previously.
5.Click Send in order to begin the Xmodem transfer.
6.
Boot the new image that you just copied over with the Xmodem procedure.
Issue the boot flash:filename command, as this example shows:
switch: boot flash:c2955-i6q4l2-mz.121-13.EA1.bin
Loading "flash:c2955-i6q4l2-mz.121-13.EA1.bin"...###############################
!--- Output suppressed.
Press RETURN to get started!
Switch>
Thanks.
01-08-2014 08:55 AM
Give us some background on this situation. Can we assume this was a production switch that was working until you upgraded the IOS?
Sounds like this is a standalone 2960 yes? Give us more information about the process you took to get to where we are now. Do you have console access to the switch?
Let us know, did you happen to leave the old IOS in flash? I'm guessing not as it is not booting..might have to do a recovery, easy steps for you here
01-08-2014 12:07 PM
Console into the switch and reboot the switch. Post the entire bootup process.
Sent from Cisco Technical Support Wii App
01-08-2014 10:47 PM
Hi.
I manage to conect to the switch with console and i get this message :
Using driver version 1 for media type 1
Base ethernet MAC Address: 20:3a:07:c1:85:80
Xmodem file system is available.
The password-recovery mechanism is enabled.
Initializing Flash...
mifs[2]: 0 files, 1 directories
mifs[2]: Total bytes : 3870720
mifs[2]: Bytes used : 1024
mifs[2]: Bytes available : 3869696
mifs[2]: mifs fsck took 0 seconds.
mifs[3]: 0 files, 1 directories
mifs[3]: Total bytes : 27998208
mifs[3]: Bytes used : 1024
mifs[3]: Bytes available : 27997184
mifs[3]: mifs fsck took 1 seconds.
...done Initializing Flash.
done.
Loading "flash:/c2960-lanlitek9-mz.122-55.SE5/c2960-lanlitek9-mz.122-55.SE5.bin"...flash:/c2960-lanlitek9-mz.122-55.SE5/c2960-lanlitek9-mz.122-55.SE5.bin: no such file or directory
Error loading "flash:/c2960-lanlitek9-mz.122-55.SE5/c2960-lanlitek9-mz.122-55.SE5.bin"
Interrupt within 5 seconds to abort boot process.
Boot process failed...
The system is unable to boot automatically. The BOOT
environment variable needs to be set to a bootable
image.
switch:
Please tell me how can i copy the image to the switch.
Thank you
01-09-2014 12:37 AM
Someone loaded the wrong IOS.
Check to make sure the old and correct IOS is not there.
flash_init
dir flash:
Post the output to the command "dir flash:".
If it's not there, then go here: http://www.cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a008015bfac.shtml
01-09-2014 04:57 AM
Steps are:
6.
Switch>
Thanks.
01-10-2014 01:07 PM
Thnak you all. It was very helpful.
