Webcast-Catalyst9k
WRVS4400N and QuickVPN problem
Hi!
I bought a router Cisco WRVS4400N Wireless-N Gigabit Security Router - VPN v2.0 with the intention of using with the QuickVPN Clien for connecting to my home network.
My home network is connected to a pre provide by my ISP Thomson TG784 and is connected to it but all my main network is controlled by the WRVS4400N, I have forward all the doors, as you can see by the log part below, and by analysing the log you can see that I can't get any PING to complete the VPN connection, can you help me?
OS is windows 7
QuickVPN Clien is 1.4.2.1
WRVS4400N firmware is v2.0.2.1
Thomson TG784 firmware is 8.4.2.Q
I would appreciate the help you could give me since this works or should work as my support way from home and i have important documents and programs to accessed, I thought this would be easier.
Any more details please just ask.
Log from QuickVPN
2012/01/11 19:44:03 [STATUS]One network interface detected with IP address 192.165.0.196
2012/01/11 19:44:03 [STATUS]Connecting...
2012/01/11 19:44:03 [DEBUG]Input VPN Server Address = husportugal.dnsalias.com
2012/01/11 19:44:03 [STATUS]OS Version: Windows 7
2012/01/11 19:44:03 [STATUS]Windows Firewall Domain Profile Settings:  OFF
2012/01/11 19:44:03 [STATUS]Windows Firewall Private Profile Settings: ON
2012/01/11 19:44:05 [STATUS]Connecting to remote gateway with IP address: 188.82.148.228
2012/01/11 19:44:11 [STATUS]Remote gateway was reached by https ...
2012/01/11 19:44:11 [STATUS]Provisioning...
2012/01/11 19:44:23 [STATUS]Success to connect.
2012/01/11 19:44:23 [STATUS]Tunnel is configured. Ping test is about to start.
2012/01/11 19:44:23 [STATUS]Verifying Network...
2012/01/11 19:44:29 [WARNING]Failed to ping remote VPN Router!
2012/01/11 19:44:32 [WARNING]Failed to ping remote VPN Router!
2012/01/11 19:44:35 [WARNING]Failed to ping remote VPN Router!
2012/01/11 19:44:38 [WARNING]Failed to ping remote VPN Router!
2012/01/11 19:44:41 [WARNING]Failed to ping remote VPN Router!
2012/01/11 19:44:46 [WARNING]Ping was blocked, which can be caused by an unexpected disconnect.
2012/01/11 19:45:04 [WARNING]Failed to ping remote VPN Router!
2012/01/11 19:45:07 [WARNING]Failed to ping remote VPN Router!
2012/01/11 19:45:10 [WARNING]Failed to ping remote VPN Router!
2012/01/11 19:45:13 [WARNING]Failed to ping remote VPN Router!
2012/01/11 19:45:16 [WARNING]Failed to ping remote VPN Router!
2012/01/11 19:45:23 [WARNING]Ping was blocked, which can be caused by an unexpected disconnect.
2012/01/11 19:45:25 [STATUS]Disconnecting...
2012/01/11 19:45:33 [STATUS]Success to disconnect.
2012/01/11 19:48:05 [STATUS]OS Version: Windows 7
2012/01/11 19:48:05 [STATUS]Windows Firewall Domain Profile Settings: ON
2012/01/11 19:48:05 [STATUS]Windows Firewall Private Profile Settings: ON
2012/01/11 19:48:06 [STATUS]One network interface detected with IP address 192.165.0.196
2012/01/11 19:48:06 [STATUS]Connecting...
2012/01/11 19:48:06 [DEBUG]Input VPN Server Address = husportugal.dnsalias.com
2012/01/11 19:48:08 [STATUS]Connecting to remote gateway with IP address: 188.82.148.228
2012/01/11 19:48:13 [STATUS]Remote gateway was reached by https ...
2012/01/11 19:48:13 [STATUS]Provisioning...
2012/01/11 19:48:26 [STATUS]Success to connect.
2012/01/11 19:48:26 [STATUS]Tunnel is configured. Ping test is about to start.
2012/01/11 19:48:26 [STATUS]Verifying Network...
2012/01/11 19:48:32 [WARNING]Failed to ping remote VPN Router!
2012/01/11 19:48:35 [WARNING]Failed to ping remote VPN Router!
2012/01/11 19:48:38 [WARNING]Failed to ping remote VPN Router!
2012/01/11 19:48:41 [WARNING]Failed to ping remote VPN Router!
2012/01/11 19:48:44 [WARNING]Failed to ping remote VPN Router!
2012/01/11 19:48:49 [WARNING]Ping was blocked, which can be caused by an unexpected disconnect.
2012/01/11 19:50:13 [WARNING]Failed to ping remote VPN Router!
2012/01/11 19:50:16 [WARNING]Failed to ping remote VPN Router!
2012/01/11 19:50:19 [WARNING]Failed to ping remote VPN Router!
2012/01/11 19:50:22 [WARNING]Failed to ping remote VPN Router!
2012/01/11 19:50:25 [WARNING]Failed to ping remote VPN Router!
2012/01/11 19:50:31 [WARNING]Ping was blocked, which can be caused by an unexpected disconnect.
2012/01/11 19:50:35 [STATUS]Disconnecting...
2012/01/11 19:50:44 [STATUS]Success to disconnect.
2012/01/11 19:51:40 [STATUS]OS Version: Windows 7
2012/01/11 19:51:40 [STATUS]Windows Firewall Domain Profile Settings: ON
2012/01/11 19:51:40 [STATUS]Windows Firewall Private Profile Settings: ON
2012/01/11 19:51:40 [STATUS]One network interface detected with IP address 192.165.0.196
2012/01/11 19:51:40 [STATUS]Connecting...
2012/01/11 19:51:40 [DEBUG]Input VPN Server Address = husportugal.dnsalias.com
2012/01/11 19:51:41 [STATUS]Connecting to remote gateway with IP address: 188.82.148.228
2012/01/11 19:51:45 [STATUS]Remote gateway was reached by https ...
2012/01/11 19:51:45 [STATUS]Provisioning...
2012/01/11 19:51:57 [STATUS]Success to connect.
2012/01/11 19:51:57 [STATUS]Tunnel is configured. Ping test is about to start.
2012/01/11 19:51:57 [STATUS]Verifying Network...
2012/01/11 19:52:02 [WARNING]Failed to ping remote VPN Router!
2012/01/11 19:52:05 [WARNING]Failed to ping remote VPN Router!
2012/01/11 19:52:08 [WARNING]Failed to ping remote VPN Router!
2012/01/11 19:52:11 [WARNING]Failed to ping remote VPN Router!
2012/01/11 19:52:14 [WARNING]Failed to ping remote VPN Router!
2012/01/11 19:52:20 [WARNING]Ping was blocked, which can be caused by an unexpected disconnect.
2012/01/11 19:54:29 [STATUS]Disconnecting...
2012/01/11 19:54:38 [STATUS]Success to disconnect.
Final message
Log from WRVS4400N
Jan 15 10:12:53 - [VPN Log]: added connection description "Casa_rw_rw"
Jan 15 10:12:54 - [VPN Log]: listening for IKE messages
Jan 15 10:12:54 - [VPN Log]: forgetting secrets
Jan 15 10:12:54 - [VPN Log]: loading secrets from "/etc/ipsec.secrets"
Jan 15 10:13:06 - [VPN Log]: packet from 81.166.45.217:50827: ignoring Vendor ID payload [MS NT5 ISAKMPOAKLEY 00000008]
Jan 15 10:13:06 - [VPN Log]: packet from 81.166.45.217:50827: ignoring Vendor ID payload [RFC 3947]
Jan 15 10:13:06 - [VPN Log]: packet from 81.166.45.217:50827: ignoring Vendor ID payload [draft-ietf-ipsec-nat-t-ike-02_n]
Jan 15 10:13:06 - [VPN Log]: packet from 81.166.45.217:50827: ignoring Vendor ID payload [FRAGMENTATION]
Jan 15 10:13:06 - [VPN Log]: packet from 81.166.45.217:50827: ignoring unknown Vendor ID payload [fb1de3cdf341b7ea16b7e5be0855f120]
Jan 15 10:13:06 - [VPN Log]: packet from 81.166.45.217:50827: ignoring Vendor ID payload [Vid-Initial-Contact]
Jan 15 10:13:06 - [VPN Log]: packet from 81.166.45.217:50827: ignoring unknown Vendor ID payload [e3a5966a76379fe707228231e5ce8652]
Jan 15 10:13:06 - [VPN Log]: "Casa_rw_rw"[1] 81.166.45.217 #5: responding to Main Mode from unknown peer 81.166.45.217
Jan 15 10:13:06 - [VPN Log]: "Casa_rw_rw"[1] 81.166.45.217 #5: transition from state STATE_MAIN_R0 to state STATE_MAIN_R1
Jan 15 10:13:06 - [VPN Log]: "Casa_rw_rw"[1] 81.166.45.217 #5: STATE_MAIN_R1: sent MR1, expecting MI2
Jan 15 10:13:07 - [VPN Log]: "Casa_rw_rw"[1] 81.166.45.217 #5: transition from state STATE_MAIN_R1 to state STATE_MAIN_R2
Jan 15 10:13:07 - [VPN Log]: "Casa_rw_rw"[1] 81.166.45.217 #5: STATE_MAIN_R2: sent MR2, expecting MI3
Jan 15 10:13:07 - [VPN Log]: "Casa_rw_rw"[1] 81.166.45.217 #5: Main mode peer ID is ID_IPV4_ADDR: '192.165.0.181'
Jan 15 10:13:07 - [VPN Log]: "Casa_rw_rw"[2] 81.166.45.217 #5: deleting connection "Casa_rw_rw" instance with peer 81.166.45.217 {isakmp=#0/ipsec=#0}
Jan 15 10:13:07 - [VPN Log]: "Casa_rw_rw"[2] 81.166.45.217 #5: I did not send a certificate because I do not have one.
Jan 15 10:13:07 - [VPN Log]: "Casa_rw_rw"[2] 81.166.45.217 #5: transition from state STATE_MAIN_R2 to state STATE_MAIN_R3
Jan 15 10:13:07 - [VPN Log]: "Casa_rw_rw"[2] 81.166.45.217 #5: STATE_MAIN_R3: sent MR3, ISAKMP SA established {auth=OAKLEY_PRESHARED_KEY cipher=oakley_3des_cbc_192 prf=oakley_md5 group=modp1024}
Jan 15 10:13:07 - [VPN Log]: "Casa_rw_rw"[2] 81.166.45.217 #6: responding to Quick Mode {msgid:01000000}
Jan 15 10:13:07 - [VPN Log]: "Casa_rw_rw"[2] 81.166.45.217 #6: transition from state STATE_QUICK_R0 to state STATE_QUICK_R1
Jan 15 10:13:07 - [VPN Log]: "Casa_rw_rw"[2] 81.166.45.217 #6: STATE_QUICK_R1: sent QR1, inbound IPsec SA installed, expecting QI2
Jan 15 10:13:09 - [VPN Log]: "Casa_rw_rw"[2] 81.166.45.217 #6: route-client output: 0
Jan 15 10:13:09 - [VPN Log]: "Casa_rw_rw"[2] 81.166.45.217 #6: transition from state STATE_QUICK_R1 to state STATE_QUICK_R2
Jan 15 10:13:09 - [VPN Log]: "Casa_rw_rw"[2] 81.166.45.217 #6: STATE_QUICK_R2: IPsec SA established {ESP=>0xbc07c0e1 <0xd7ef396d xfrm=3DES_0-HMAC_MD5 NATD=none DPD=none}
Jan 15 10:13:29 - [VPN Log]: "Casa_rw_rw"[2] 81.166.45.217 #5: received Delete SA(0xbc07c0e1) payload: deleting IPSEC State #6
Jan 15 10:13:29 - [VPN Log]: "Casa_rw_rw"[2] 81.166.45.217 #5: terminating SAs using this connection
Jan 15 10:13:29 - [VPN Log]: "Casa_rw_rw" #6: deleting state (STATE_QUICK_R2)
Jan 15 10:13:29 - [VPN Log]: "Casa_rw_rw" #5: deleting state (STATE_MAIN_R3)
Jan 15 10:13:29 - [VPN Log]: "Casa_rw_rw"[2] 81.166.45.217: deleting connection "Casa_rw_rw" instance with peer 81.166.45.217 {isakmp=#0/ipsec=#0}
Jan 15 10:13:30 - [VPN Log]: "Casa_rw_rw": unroute-client output: 0
Jan 15 10:13:30 - [VPN Log]: packet from 81.166.45.217:50827: received and ignored informational message
Jan 15 10:13:30 - [VPN Log]: packet from 81.166.45.217:50827: Informational Exchange is for an unknown (expired?) SA
Jan 15 10:13:31 - [VPN Log]: "Casa_rw_rw": deleting connection
If someone could help me...
Thank you,
Alex
554
