Webcast-Catalyst9k
WS-C3750E-24TD-S
Is the 10GB gig modules slots "standard" with 3750E. instead of using the 10GB twin GBIC module, can i just connect 2 individual single SFP to the WS-C3750E-24TD-S to create a 2GB trunk etherchannels? I dont need 10GB conenctivity. All is need is to connect a 2GB etherchannel between two WS-C3750E! Please advise.
Re: WS-C3750E-24TD-S
Hi Francisco,
With every 3750-E, you have a twin-gig converter shipped free which gives you flexibility to plug in 2 SFP's in a single twin-gig converter. You can use the same convereter and can have a 2gig ether-channel.
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps7077/prod_qas0900aecd805bbea5.html
HTH,
-amit singh
Is there a website where I can find how the interfaces are referenced for a specific model? Can be a problem if you don't have the device yet ;-)
Eg:
3750E-24TD-S:
gig1/0/1-24
Tengig1/0/1-2 ??
with twingig module: ?? gig1/0/25-26 and gig1/0/27/28??
658
