WS-C6509-E 15.1(1)SY1.
Hi, all.
What do these messages mean in "sh logg" command?
004336: Nov 25 10:25:01.678 TOM: %EARL-4-L3LIF_INTERNAL: There was a software error in the L3 interface Table Manager
004337: Nov 25 10:25:01.678 TOM: %EARL_CM-5-LIFACCESS: LIF access failed.
-Traceback= 82CE374z 82C19CCz 83480B0z 8348594z 74FB0B0z 524CEA0z 5246734z
004338: Nov 25 10:25:01.682 TOM: %QM-4-LIF_PROPERTY: Hardware LIF property programming failed for slot 5 intf Gi9/8 dir IN: <PROPERTY_UPDATE- exception:[no] oir:[no] prop_id:[ilm_plcr_base] prop_val:[152]> Prop Udp Error: FAIL (1)
004339: Nov 25 10:26:01.682 TOM: %EARL-4-L3LIF_INTERNAL: There was a software error in the L3 interface Table Manager
004340: Nov 25 10:26:01.682 TOM: %EARL_CM-5-LIFACCESS: LIF access failed.
004341: Nov 25 10:26:01.686 TOM: %QM-4-LIF_PROPERTY: Hardware LIF property programming failed for slot 5 intf Gi9/8 dir IN: <PROPERTY_UPDATE- exception:[no] oir:[no] prop_id:[ilm_plcr_base] prop_val:[152]> Prop Udp Error: FAIL (1)
004342: Nov 25 10:26:01.690 TOM: %QM-4-TCAM_ENTRY: Hardware TCAM entry programming failed for slot 5 intf Gi9/8 dir IN: <CONFIG_UPDATE_REQ> TCAM Req Error: FAIL (4): Low TCAM Entries (1)
004343: Nov 25 10:26:01.690 TOM: %QM-4-TCAM_ENTRY: Hardware TCAM entry programming failed for slot 5 intf Gi9/8 dir IN: <CONFIG_UPDATE_REQ> TCAM Req Error: FAIL (4): Low TCAM Entries (1)
004344: Nov 25 10:26:01.690 TOM: %QM-4-TCAM_ENTRY: Hardware TCAM entry programming failed for slot 5 intf Gi9/8 dir IN: <CONFIG_UPDATE_REQ> TCAM Req Error: FAIL (4): Low TCAM Entries (1)
004345: Nov 25 10:26:01.690 TOM: %QM-4-TCAM_ENTRY: Hardware TCAM entry programming failed for slot 5 intf Gi9/8 dir IN: <CONFIG_UPDATE_REQ> TCAM Req Error: FAIL (4): Low TCAM Entries (1)
004346: Nov 25 10:26:01.690 TOM: %QM-4-TCAM_ENTRY: Hardware TCAM entry programming failed for slot 5 intf Gi9/8 dir IN: <CONFIG_UPDATE_REQ> TCAM Req Error: FAIL (4): Low TCAM Entries (1)
Thanks!
224
