WS-X6348-RJ-45 not responding on Cisco 6506
I installed a WS-X6348-RJ-45 into a Cisco 6506 switch on slot 3. My IOS version is s72033-pk9s-mz.122-18.SXD5.bin.
The card keep giving the following errors below.
Mod Ports Card Type Model Serial No.
3 48 48 port 10/100 mb RJ45 WS-X6348-RJ-45 SAL0704C6M9
5 2 Supervisor Engine 720 (Active) WS-SUP720-3B SAL1033Y3R8
Mod MAC addresses Hw Fw Sw Status
3 000b.fdad.2b58 to 000b.fdad.2b87 7.0 5.4(2) 8.3(0.156)RO PwrDown
5 0016.9df6.9570 to 0016.9df6.9573 5.2 8.4(2) 12.2(18)SXD5 Ok
Mod Sub-Module Model Serial Hw Status
5 Policy Feature Card 3 WS-F6K-PFC3B SAL1032XKA0 2.3 Ok
5 MSFC3 Daughterboard WS-SUP720 SAL1033Y6K7 2.5 Ok
Mod Online Diag Status
3 Unknown
5 Pass
00:01:42: %PM_SCP-SP-6-LCP_FW_ERR_INFORM: Module 3 is experiencing the following
error: Coil Master CPU Interface Error - Coil #2
00:01:47: %PM_SCP-SP-6-LCP_FW_ERR_INFORM: Module 3 is experiencing the following
error: Coil Master CPU Interface Error - Coil #3
00:01:52: %PM_SCP-SP-6-LCP_FW_ERR_INFORM: Module 3 is experiencing the following
error: Coil Master CPU Interface Error - Coil #0
00:01:59: %DIAG-SP-3-MAJOR: Module 3: Online Diagnostics detected a Major Error.
Please use 'show diagnostic result <target>' to see test results.
00:01:59: %OIR-SP-3-LC_FAILURE: Module 3 has Major online diagnostic failure, Ca
rd will be powered down. Please check bootflash diaginfo file for detailed diagn
ostic result.
00:01:59: %C6KPWR-SP-4-DISABLED: power to module in slot 3 set off (Diagnostic F
ailure)
KAD-SW01#
Hall of Fame Super Silver
Re: WS-X6348-RJ-45 not responding on Cisco 6506
hello Olaosebikan,
try to reseat the linecard
try it in another slot
if the behaviour doesn't change ask for replacement
Hope to help
Giuseppe
Hall of Fame Super Gold
"Major online diagnostic failure" sounds like a hardware failure.
710
