Webcast-Catalyst9k
X. 25 Connect
our customer wants to use a 2821 gateway with an E1 controller in order to receive data via X.25.
Does anybody know how to configure this?
Thet gateway should answer the call and redirect it to an internal host.
Best regards Bjoern
Hall of Fame Super Silver
Re: X. 25 Connect
Hello Bjoern,
X25 can be transported over TCP in the so called XoT tunnels see
http://www.cisco.com/en/US/docs/ios/termserv/configuration/guide/tsv_pad_x25_connect_ps6441_TSD_Products_Configuration_Guide_Chapter.html#wp1013650
and dial commands to accept X.25 over an isdn
http://www.cisco.com/en/US/docs/ios/dial/configuration/guide/dia_cfg_x25_isdn_ps6441_TSD_Products_Configuration_Guide_Chapter.html
All examples I see are based on BRI and not PRI
for sure X.25 over D channel is supported only with BRI
X.25 traffic over the D channel can be used as a primary interface where low-volume, sporadic interactive traffic is the normal mode of operation. Supported traffic includes the Internet Protocol Exchange (IPX), AppleTalk, transparent bridging, Xerox Network Systems (XNS), DECnet, and IP.
This feature is not available on the ISDN PRI.
see config of peso router in this example it is using a PRI and it is used as an X25 switch
http://www.cisco.com/en/US/docs/ios/dial/configuration/guide/dia_cfg_x25_isdn_ps6441_TSD_Products_Configuration_Guide_Chapter.html#wp1000968
Hope to help
Giuseppe
Re: X. 25 Connect
Hi Giuseppe,
many thanks for your detailled reply!
If I understood correctly, X.25 over ISDN can only be configure on BRI not on PRI correct ???
Regards Bjoern
Re: X. 25 Connect
Hello Bjoern,
that was my first impression.
However, ISDN over D channel is a special case and that is supported only on BRI
I just remember we moved XoT tunnels over an MPLS VPN with good results.
if you see config  of peso router in last example it is performing X.25 routing and it uses a PRI
X.25 is layer3 OSI so it configured with its own static routes and special mappings. This is what I can say
Hope to help
Giuseppe
Re: X. 25 Connect
Hello Giuseppe,
many thanks once more for your fast assistance, I'll have a try on monday :-)
Regards Bjoern
Hall of Fame Super Gold
Re: X. 25 Connect
This is easily done, look for "protocol translation" in the manual,
213
