X.25 LAPD Network over a 3G Network
Hello Everybody,
I have to do a lab (for a client) with the following architecture : A central router which is by one interface attached to an IP/MPLS network, the other interface is serving a central Host X.25. A remote router with a 3G HWIC embedded that is connected to the ISP Network and the other interface is serving a X.25 host. The ISP is doing a GRE Tunnel to link the Hub Router and the Spoke.
I have to validate that it is possible to have full reachability between central site and the remote agents...
The problem is how to do everything ?...
I have to run X.25 over a 3G (IP) network and the ISP is bringing us X.25 on the D Channel.
If anyone has an idea on how to do that...
Thanks a lot for your help.
Pierre-Louis
1 REPLY
Hall of Fame Super Gold
Re: X.25 LAPD Network over a 3G Network
Hi, you would use XOT and X.25 on BRI D channel, and it will work.
Many networks are like this and doesn't matter the physical network type as long IP and XOT are properly configured.
378
