Webcast-Catalyst9k
X.25 SVC's rejected - international link busy
I have the following problem: multiple simultaneous connections (SVC's) get rejected by the router, usually after the 4th LCI has been established.
I'm using a Cisco 2500 router, with IOS Enterprise 12.
Do you know the solution to this problem (the debug error message is (Cause 0, Diag 116 (DTE originated/International link busy)) ?
Thanks very much.
tvconsultoria@tvconsultoria.com.br
1 ACCEPTED SOLUTION
Silver
Re: X.25 SVC's rejected - international link busy
There may be a few reasons for this.So, to further trace it through, i want u to send me the following debugs :
deb pad
deb x25 eve
debug translation
A factfile reason for this problem is the router not allowing many no of TCP sessions.If this is the case,then change the line vty cmd values.
Silver
deb pad
deb x25 eve
debug translation
Hi Sam,
Sounds like you know a little about X25.
Would you mind having a look at my post (X25 HELP - posted 21-12-05).
140
