Community Member
x25 QLLC and IBM Host
Hi all,
we are trying to configure a scenario in which an IBM Host starts a call over X25 cloud to 3 different X25 clients. The mainframe is attache to a 3745 router via Osa an fast Ethernet (0/0). Serial 2/6 on router is attacehed to X25.
Host---osa--FE---Router---Serial2/6--X25---3 different x24 clients with 3 differents X25 addresses.
We have tested the following configurations for the router:
Conf 1
interface Serial2/6
description Prueba para X25 QLLC con
no ip address
encapsulation x25 ietf
no ip mroute-cache
x25 address 007599801
x25 alias .*
x25 ltc 2
x25 htc 6
x25 facility windowsize 7 7
x25 facility packetsize 128 128
x25 map qllc 4000.0090.9910 12003022
x25 map qllc 4000.0090.9911 12004212
x25 map qllc 4000.0090.9909 12005211
no cdp enable
qllc accept-all-calls
qllc dlsw vmacaddr 4000.0090.9909 3
Clients x25 addresses are 12005211, 12004212 and 12003022 and macs 4000.0090.99xx are mac addr where hsot PU's point to inicatiate the call.
In this conf qe can only start an x25 conversation from host at a time.
Conf 2
interface Serial2/6
description Prueba para X25 QLLC con BOLSA XN024
no ip address
no ip mroute-cache
shutdown
x25 alias .*
x25 ltc 2
x25 htc 6
x25 map qllc 1200
no cdp enable
qllc dlsw subaddress 5211 vmacaddr 4000.0090.9909 partner 4000.000c0.8a
qllc dlsw subaddress 3022 vmacaddr 4000.0090.9910 partner 4000.000c0.8a
qllc dlsw subaddress 4211 vmacaddr 4000.0090.9910 partner 4000.000c0.8a
end
This conf was checked form doc DLSW+ Design and Implementation Guide (Chapter 2 figure 2-10).
This conf 2 does not work. It seems x25 connection is restarted but nothing else. No Data tranfer.
Dlsw conf has been prior tested and it is working.
Coul you please help?
Silver
Re: x25 QLLC and IBM Host
If QLLC is configured, the router answers an X.25 QLLC call with an X.25 CALL CONNECTED message. The router then sends a test frame, or explorer, to the LAN device to initiate the LAN connection. If the LAN partner can be located, the LAN partner sends an explorer response with a RIF on how to locate it.
Community Member
Hi b.shu,
butc in our case is the HOST who is INITIATING the call. SO can U check if we need anything else ?
Thx
Community Member
At the end we have succeded based on configuration n#1.
TRicky are comtiguous vmacs on router (number ov vmacs also = pool size), canonical to non-canonical transform, and x25 remote addresses.
Rgds
Community Member
Bunos dia,puede por favor,postar un exemplo de tua configuration sobre el router y tambien un exemplo de lo che has definido sobre host ?
Gracias
289
