Webcast-Catalyst9k
X25 routing
I am configuring X25 static routes. Is it possible to configure a specific X25 route after a .* route like so or is it like IP where the X25 route ^135301288 will never be used because of the .* route above:-
x25 route 011040098 xot 19.46.115.5
x25 route .* interface Serial3/2
x25 route ^135301288 xot 10.70.0.214 xot-source Serial3/2
1 REPLY
Re: X25 routing
you should place the .* route at the end. In your case "x25 route ^135301288 xot 10.70.0.214 xot-source Serial3/2" will not be used. In case you add a route it is appended unless you specify a position:
x25 route [#position] x121-address [cud pattern] ip ip-address
With the help of the "#position" parameter you can sort the routes properly for your needs.
Hope this helps! Pllease rate all posts.
Regards, Martin
113
