03-28-2008 07:08 PM - edited 03-03-2019 09:19 PM
I have just finished uploading "xmodemed" a new ios image to a router (3640) and instead of restarting thereafter so that i may change the console and baud rates, the system went into the following output:
rommon 2 > reset
System Bootstrap, Version 11.1(20)AA2, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
Copyright (c) 1999 by cisco Systems, Inc.
C3600 processor with 131072 Kbytes of main memory
Main memory is configured to 64 bit mode with parity disabled
rommon 1 > xmodem -c c3640-ik9o3-mz.124-13b
Do not start the sending program yet...
File size Checksum File name
32585912 bytes (0x1f138b8) 0xbb3c c3640-jk9o3s-mz.124-10b.bin
WARNING: All existing data in flash will be lost!
Invoke this application only for disaster recovery.
Do you wish to continue? y/n [n]: y
Ready to receive file c3640-ik9o3-mz.124-13b ...
Erasing flash at 0x31fc0000
program flash location 0x300e0000
I just hope someone out there can decipher what this output means?
Thank you
03-29-2008 02:33 AM
Just check can your router load now with the new IOS ??? if yes then its fine or else just let me know what ouput you are getting now ??? can you tell me how much RAM you have ?
03-29-2008 03:26 AM
The problem is that i can not even get into the privilege or global configuration mode. The baud rate remains 115200 8 N 1, which always result back to rommon> mode.
Any changes to the console/baud rate to 9600 8 N 1, always produced unwanted characters on the CLI.
Hope with this explanation someone could help me further?
03-29-2008 05:01 AM
did you boot the router with the new IOS through boot command......? Use the 12th step n do let me know.
03-29-2008 07:32 AM
Hello, Thanks for the reply. Unfortunately the link you sent talks about 3560 catalyst while my problem is on 3640 router.
Hope you can still help me further?
03-30-2008 02:11 AM
Dear,
http://www.cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a008015bfac.shtml#proc_3600 hope you find a solution through this.
04-20-2009 07:24 AM
Were you ever able to resolve this? I've had the same issue and thought I could get some insight from you.
Thanks.
