AsyncOS 6.3.1-025 and 6.0.2-017 for Web are GA
Dear Cisco IronPort Customer,
IronPort, now part of Cisco, is pleased to announce the General Availability (GA) of the two maintenance releases of AsyncOS 6.3.1-025 for Web and 6.0.2-017 for Web to all customers. These releases applies to all our Web Security Appliances (S-Series).
Enhancements and Fixes in AsyncOS 6.3.1-025 for Web
Partial list of defects fixed in 6.3.1-025
* Fixed: Web Security appliance spontaneously reboots due to a slow memory leak when clients used NTLMv1 authentication in some cases. [Defect ID: 52548]
* Fixed: Webroot scanning engine stops working when downloading some .cab files. [Defect ID: 53793]
* Fixed: Web Proxy generates a core file after a client sends a POST request to a server that returns a 503 “Service Unavailable” message in some cases. [Defect ID: 54019]
* Fixed: Web interface erroneously shows 100% CPU utilization when rate is lower. [Defect ID: 54767]
* Fixed: Web Proxy generates a core file and restarts in some cases. [Defect ID: 54890]
* Fixed: Web Proxy generates a core file and restarts after processing some HTTPS requests in some cases. [Defect ID: 55407]
Enhancements and Fixes in AsyncOS 6.0.2-017 for Web
Partial list of defects fixed in 6.0.2-017
* Enhancement: Added support for NTLM proxy authentication against Windows 2008 Server R2. [Defect ID: 49114]
* Fixed: WBNP engine erroneously runs at 100% due to a memory leak. [Defect ID: 54034]
* Fixed: Vulnerability in Secure Sockets Layer (SSL) certificates. [Defect ID: 55278]
For further information about these releases, please refer to the AsyncOS Release Notes. The release notes are available on our Support Portal:
https://supportportal.ironport.com
If you are concerned about an issue not listed there, please contact your authorized support provider to make an inquiry.
How to Upgrade
Prior to upgrading, please read the Release Notes referenced above and save a copy of the configuration file somewhere other than on your appliance.
Once you have read the Release Notes you may log into the command line of your IronPort Appliance as the 'admin' user, and type 'upgrade', or use the WebUI upgrade functionality in the "System Administration" tab.
**NOTE** It is important that you follow the upgrade instructions available in the Release Notes. If you do attempt to upgrade and do not see the desired release version available, your appliance is likely not on a version allowed to upgrade directly. See 'Upgrade Paths', below.
Upgrade Paths
Please refer to the Release Notes for qualified upgrade paths.
If your systems are on any other AsyncOS release, you will need to perform multiple upgrades as specified in the release notes. Only the immediate next step in the upgrade path will be shown to you, with the next revision being shown once you are at the approved level.
Release Stage
General Availability (GA): This release is available to all our customers and is a recommended build to be used in your production environments.
Thank you for choosing Cisco IronPort Security Products.
Best Regards,
Jakob
157
