08-12-2013 03:34 PM
I'm trying to add a Ironport S170 web security appliance to an Ironport M170. When doing this I recieve a message saying "Web Reporting capability check: Web Reporting version 1.0 is supported locally, but not remotely." Can someone please point me in the right direction as to what the Web reporting capability check is and how to resolve this warning message?
Ryan
Solved! Go to Solution.
08-13-2013 12:12 AM
It seems the version of SMA you are running does not support the Web Reporting engine that is now running on the WSA. Please upgrade the SMA to at least version 7.9 to utilize the centralized reporting feature. Version 7.5 for WSA utilizes Web Reporting version 2.0.
Kush
08-13-2013 12:12 AM
Kush
08-13-2013 07:51 AM
Thanks Kush. It worked perfectly. I appreciate the response.
