scansafe with AD on ISR G2
We are using scansafe and would like to authenticate users with Active Directory when connecting to internet. user is redirected to the URL "webproxy/login" and cannot open the page.
There is no active session when I check in the router (with the command "show content-scan session active").
Plese, find below the step I followed for the configuration with Active Directory. Is there any other configuration I should do or modify.
- On the router
                parameter-map type content-scan global
                 server scansafe primary name proxy1.scansafe.net port http 8080 https 8080
                 server scansafe secondary name proxy2.scansafe.net port http 8080 https 8080
                 source interface GigabitEthernet0/0
                 user-group ciscogroup username ciscouser
                 server scansafe on-failure allow-all
                aaa new-model
                aaa group server ldap scansafe-ldap-group
                 server scansafe-ldap-server
                aaa authentication login ss-aaa group scansafe-ldap-group
                aaa authorization network ss-aaa group scansafe-ldap-group
                aaa accounting network ss-aaa none
                aaa session-id common
                ip admission virtual-ip 1.1.1.1 virtual-host webproxy
                ip admission name ssauth ntlm
                ip admission name ssauth order   ntlm
                ip admission name ssauth method-list authentication ss-aaa authorization ss-aaa accounting ss-aaa
                ldap attribute-map ldap-username-map
                 map type sAMAccountName username
                ldap server scansafe-ldap-server
                 ipv4 <IP_AD>
                 attribute map ldap-username-map
                 bind authenticate root-dn cn=test_scan,cn=users,dc=our_domain,dc=local password <Psw>
                 base-dn cn=users,dc=our_domain,dc=local
                 search-filter user-object-type top
                 authentication bind-first
                description WAN
                content-scan out
                interface GigabitEthernet0/1
                description LAN
                ip admission ssauth
I tried to use transport port 3268, then 389 but the result is the same.
- on AD
Creat the user test_scan under users and another user for test I tried to use only one user, without group, at the first time.
- On scansafe webpage
1). Admin -> Management -> Groups.
2). Add Directory Groups (WinNT://our_domain.local\users).
3). Web Filtering ->Management-> Policy and use the default filter/allow for the Directory group
I also tried to creat a realm under Admin->Authentication->Management->Add LDAP Realm / select the group to use (CN=Users,DC=nexthope,DC=local) I did the following checks successfully
- connection
- authentication
- check LDAP
Best regards
434
