05-06-2024 09:10 AM
We are using Webex Calling
When a caller places a call, it rings twice and then goes silent. On the recipients end it rings the set number of times (6 in our case) and then goes to voicemail if the recipient cannot get to the phone in time.. The caller will get sent to voicemail if they wait long enough but usually they find the silence disconcerting and hang up .
I am sure this will turn out to be a simple setting but I am not sure where to look.
05-06-2024 11:11 AM
@pjyoung, would you please provide some additional information? Include if this is internal calls only, external calls only or all calls. If the recipient answers the phone, do both parties have audio?
05-06-2024 12:28 PM
This happens to both internal and external callers. If the recipient does answer both parties have audio. The calls are normal apart from this issue
