Cisco Presence Profile 52 - need to block incoming calls
We have complete TP infrastructure running. All the Incoming/outgoing calls are working fine from all the video endpoints. but need to block one of the Profile 52 video device Incoming calls  from VCSC / VCSE. nobody cannot reach to the endpoint only outgoing should enabled.
How its possible. Please advise
TP setup details;
system configured SIP dialing based. Multiway
H323- Inactive
TMS is using for the endpoints management.
1 ACCEPTED SOLUTION
HI Ashiq,The hardware support
HI Ashiq,
The hardware support you are looking for is not on this forum.  However, you cannot block calls from your VCS to an individual endpoint.  This can be managed at the endpoint itself using the "Do Not Disturb" feature.  Access the webUI and the feature can be found under "Configuration" or "System Configuration" depending on the firmware version you have.  Then go to the "Conference" option on the left panel, scroll down until you see the "Do Not Disturb" section.  Change the timeout to zero and the mode to "on."  This will tell your endpoint to block all incoming calls until you manually turn this feature off.
If you need further endpoint support, please use the correct forum or call TP TAC at 800-553-2447.
Jason
HI Ashiq,
Jason
Thank you so much Mr jhirdler
Thank you so much Mr jhirdler. It works fine..!!
Really appreciated !!!
Ashiq
Ashiq
141
