Here's a form you can use fo calculate to which bucket a particular IP would be assigned:
WCCP Mask (HEX) | HEX | First Octet | Second Octet | Third Octet | Fourth Octet | Number of Buckets |
0x7F | 0x0000007F | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 128 |
IP to Calculate (Opt.) | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | IP assigned to Bucket |
192.168.0.11 | 0xC0A8000B | 1 | 1 | 0 | 0 | 0 | 0 | 0 | 0 | 1 | 0 | 1 | 0 | 1 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 1 | 0 | 1 | 1 | 11 |
Enter your WCCP Mask choice and map out the binary mask value and enter an IP address to be evaluated against the mask. Anding the values yields the bucket assignment. Since WAE WCCP Bucket assignment varies, you will need to compare this to the output of "show ip wccp [61 or 62] detail" on your router/switch, or "show wccp mask tcp-pro" on your WAE to determine the bucket to WAE mapping.
Your Cisco Account team can provide you with an excel spreadsheet that will perform these calculations automatically.
-ken
