Problem with inline module on WAE device "Disable bypass mode is on"
Hi all,
I have run into a problem with a new WAE 674 appliance with integrated inline adapter.
I did a basic setup and everything seemed to work properly until we tested the
mechanical bypass of the inline card ( power failure). Unfortunately this feature does
not work on this new WAE/inline card. I compared the configuration with some other,
already installed WAEs, and did not find any misconfiguration. I have found one
difference, though - when i do a "show interface inlinegroup 1/0" a get a line which
is:  "Disable bypass mode is on".
On all other WAEs with inline interfaces we have this line is: "Disable bypass mode is off"
Does this mean that mechanical bypass is administratively turned off ? And if so, how can this
turned on again ?
Thank you for your kind help
With kind regards
Andreas
520
