07-07-2010 05:54 AM
so far on 3 of the my device it will stop optimizing and when i login i get this
Cisco Wide Area Application Engine
WAE-0370-574 login: admin
Password:
No directory /local/local1!
Logging in with home = "/".
System Initialization Finished.
Disk based software not installed.
Some applications may not run correctly!
WAE-0370-574#
it appears like everthing has been deleted from flash
WAE-0370-574#dir
size time of last change name
WAE-0370-574#
Even when I reload the image nothing....
WAE-0370-574#sh flash
Your software installation appears to be incomplete.
(could not access /sw/UP-TO-DATE or /swstore/manifest)
Please run 'copy ftp/cdrom install' to install a new image.
System image on flash:
Version: 4.1.5f.b2
System flash directory:
System image: 185 sectors
Bootloader, rescue image, and other reserved areas: 41 sectors
256 sectors total, 30 sectors free.
WAE-0370-574#
Enterprise active 07/07/2010 admin
Video not active
Virtual-Blade not active
WAE-0370-574#
WAE-0370-574#sh accelerator
Accelerator Licensed Config State Operational State
cifs Yes Enabled Shutdown
epm Yes Enabled Shutdown
http Yes Enabled Shutdown
mapi Yes Enabled Shutdown
nfs Yes Enabled Shutdown
ssl Yes Enabled Shutdown
video No Enabled Shutdown
wafs-core Yes Disabled Shutdown
wafs-edge Yes Disabled Shutdown
WAE-0370-574#
Any suggestions ?
Solved! Go to Solution.
07-07-2010 06:20 AM
The message your receive during login indicates either a failed upgrade/install of WAAS software or hard disk failure(s). Right now this device isn't running WAAS from disk as it should (it's running a limited version off of flash), and as such will not optimize traffic.
The first step to resolve this would be to re-install the software bin image (copy ftp install
After the reload to complete the install issue the command show disk details to view the health of the disks.
Cheers,
Mike Korenbaum
Cisco WAAS PDI Help Desk
http://www.cisco.com/go/pdihelpdesk
07-07-2010 06:20 AM
Cheers,
Mike Korenbaum
