7920/ 1100 Series AP problem
Switch Configuration:
Do you trunk the port going to the AP?
AP Configurations:
Do you have to broadcast the voice (SSID) for the 7920 phone to authenticate?
Do you have to broadcast the voice (SSID) in order for the phone to layer 2 roam?
We're having problems with our current configurations:
Currently, we have the switch port configured like this:
interface FastEthernet0/48
switchport access vlan 90
switchport mode access
switchport voice vlan 15
no ip address
mls qos trust device cisco-phone
mls qos trust cos
auto qos voip cisco-phone
wrr-queue bandwidth 20 1 80 1
wrr-queue min-reserve 1 5
wrr-queue min-reserve 2 6
wrr-queue min-reserve 3 7
wrr-queue min-reserve 4 8
wrr-queue cos-map 1 0 1 2 4
wrr-queue cos-map 3 3 6 7
wrr-queue cos-map 4 5
priority-queue out
spanning-tree portfast
On the AP, we have two SSIDs, each assigned their respective vlans (Voice and Data).
On the Data VLAN, we are using DHCP.
Which ever SSID (VLAN) we broadcast, is the only one that seems to work. If we dont broadcast the voice vlan, the phones, even when configured with a specific SSID, wont work. It saids no AP found.
If we broadcast the voice, the laptops wont get their ip from the data SSID.
If someone could give me a detailed example configuration of the switch, AP, and phone (if needed), that would help a lot.
Re: 7920/ 1100 Series AP problem
you must configure the port to trunnk the vlans that you are mapping to your SSID
here is an example (of the trunking only) switch port config:
interface FastEthernet0/18
switchport trunk native vlan 400
switchport trunk allowed vlan 400,410,420,430
switchport mode trunk
Which trunks 4 vlans to the AP.
The AP config relating to the multiple ssids, vlans and bridge groups is below:
dot11 mbssid
dot11 ssid SSID4
vlan 430
authentication <>
accounting <>
mbssid guest-mode dtim-period 20
information-element ssidl advertisement wps
dot11 ssid SSID1
vlan 400
authentication <>
accounting <>
dot11 ssid SSID2
vlan 410
authentication <>
accounting <>
dot11 ssid SSID3
vlan 420
authentication <>
accounting <>
interface Dot11Radio0.400
encapsulation dot1Q 400 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.410
encapsulation dot1Q 410
no ip route-cache
bridge-group 2
bridge-group 2 subscriber-loop-control
bridge-group 2 block-unknown-source
no bridge-group 2 source-learning
no bridge-group 2 unicast-flooding
bridge-group 2 spanning-disabled
interface Dot11Radio0.420
encapsulation dot1Q 420
no ip route-cache
bridge-group 3
bridge-group 3 subscriber-loop-control
bridge-group 3 block-unknown-source
no bridge-group 3 source-learning
no bridge-group 3 unicast-flooding
bridge-group 3 spanning-disabled
interface Dot11Radio0.430
encapsulation dot1Q 430
no ip route-cache
bridge-group 4
bridge-group 4 subscriber-loop-control
bridge-group 4 block-unknown-source
no bridge-group 4 source-learning
no bridge-group 4 unicast-flooding
bridge-group 4 spanning-disabled
no ip address
no ip route-cache
****optionally use encrption on your vlans'
encryption vlan 400
ssid SSID1
ssid SSID2
ssid SSID3
ssid SSID4
no ip address
no ip route-cache
duplex auto
speed auto
hold-queue 160 in
interface FastEthernet0.1
no ip route-cache
bridge-group 1
interface FastEthernet0.2
no ip route-cache
bridge-group 2
interface FastEthernet0.3
no ip route-cache
bridge-group 3
interface FastEthernet0.4
no ip route-cache
bridge-group 4
When using SSID's with VLANS, you must trunk to the switch in order for it to work. I would also suggest using WPA-TKIP for the 7920 phones for security and roaming. I have a few customers setup that way using WDS and RADIUS and they work wonderfully.
191
