01-08-2004 01:57 PM - edited 07-04-2021 09:15 AM
Remote site has 7960 phones, Linksys WRT54-G wireless, and Cisco 827 DSL coming back to a callmanager 3.3 When we power on a 7920 phone the 7960 phones will unregister with the call manager, but the 7920 will work fine. Turn off the 7920 and the 7960's come back online. We put an Aironet 350 out there - same thing. We put an Aironet 1200 AP out there and both the 7960's and 7920's work. All of the devices are plugged into a non-cisco switch.
I've been looking on this forum and CCO, but no luck. Has anyone run into this, have any ideas, or can point me in the right direction.
Mark
01-09-2004 07:30 AM
Mark,
I've heard of several people encountering this issue. A couple of recommendations that may help:
1. Make sure short preambles are set (default on the 1200 AP, not sure about the Linksys or 350 APs).
2. Make sure Multicast is disabled on the AP (again default on the 1200 AP, not sure about the other APs).
Finally, not sure what firmware you are using on the 7920, but I'd suggest the newest version 01-06 (http://www.cisco.com/cgi-bin/tablebuild.pl/ip-7900ser-crypto).
Jordy
01-09-2004 09:50 AM
Jordy,
Thanks for the reply, I'm going out there today and will give it try.
Mark
01-12-2004 01:45 PM
Jordy,
Had to turn off cdp - works like a charm. Thanks
Mark
04-10-2004 02:01 PM
I have the same problem, where did you turn off CDP ?
on the 7920 ? on Callmanager ?
04-12-2004 05:53 AM
I figured it out, Turn off CDP on the 7920
TO do this, you need to get the 7920 into administrator mode
then go to
Network COnfig>>CDP TX Enable/Disable
Make sure that you have short RF preamble disabled on the AP or the 7920 wont even connect to the AP
