7920 and Autonomous 1242 Signal Stregth Threshold
Hello, I have six 7920 phones attaching to four 1242 autounomous APs. In a retail store environment. Users have complained about calls becoming distorted or dropping quite frequently. I can see the phones roaming from AP to AP and the lowest signal strength I have seen it hit before roaming was -71. I am not sure if there is a way to set the RSSI cut off to something like -60 for that WLAN, if there is, could someone provide details on how to do so? Or if someone has experiened similar issues, what was the workaround? Thanks in advance.
1 REPLY
Re: 7920 and Autonomous 1242 Signal Stregth Threshold
Audio quality will still be ok at -71 dBm.
In retail environments, there is potential for multipath and an 802.11b client with a non-diversity antenna may not work well unless using the lower data rates only (i.e. 1 & 2 Mbps).
Would recommend to move to the 7925 which offers 802.11a, which is also quite a bit more rugged than the 7920.
Offers Bluetooth for wireless headset communications as well.
437
