Community Member
7920 Config utility ver 3.0 Problem Connecting to Phon
Using the 7920 Config Utility 3.0. I have my 7920 phone Im trying to program... The system goes ONLINE to the phone just fine, but when I try to export the config to the phone, I get an ERR 300 "TFTP FAILS IN IMPORTING CONFIGURATION FILE." Then TFTP Server Port Number:69 , Connection Reset By Phone.
I cannot get it to work and its very frustrating... any help is appreciated!!!
Re: 7920 Config utility ver 3.0 Problem Connecting to Phon
Please be sure you are following the Installation guide for 7920 config utility.7920 USB NIC is supposed to be set for DHCP. Also ensure you are not running any TFTP server application on the PC that will also use port 69.The Configuration Utility has limited DHCP server capabilities. If the USB interface of the Cisco Wireless IP Phone 7920 is set to DHCP, the IP address should be 192.168.1.X to allow network communication between the Cisco 7920 Wireless IP Phone and the PC. The config utility will assign an IP to the PC's USB NIC.
