Community Member
7920 deauthenticating coninuously
Dear all
I m facing problem with wireless lan
I have 1130Ap and 7920IP phone with ccm 4.2,
1st phone authenticated with AP after few min its deauthenicated listed logs are related to IP phone
Jun 19 05:48:04.942 Interface Dot11Radio0, Station SEP0015f941d077 0015.f941.d077 Associated KEY_MGMT[NONE]
Jun 19 05:51:28.849 Interface Dot11Radio0, Deauthenticating Station 0015.f941.d077 Reason: Previous authentication no longer valid
kidly suggest whats i m doning wrong ?
laptops are also doing same problem after few min they also deauthenicated
I used only SSID with wep40bit encription
regards
Tahir
Re: 7920 deauthenticating coninuously
If laptop clients are doing the same then not 7920 specific. Sounds like you have a session timeout configured in the autonomous AP.
Community Member
Hi ,
Try do enable long preamle, this can help you.
see this FAQ:
http://www.cisco.com/en/US/products/ps6366/products_qanda_item09186a008064a991.shtml
PS. If the PC are IBM (a bit older pcs) the wireles NIC have had som problems , the preamble will fix this too..
/ Soren
152
