7920 roaming between two WLCs
elkono200
hi,
- i have two WLCs 4404 and 4402 in the same mobility group and all connections seem to be ok.
- one ssid for voip.
- two 7920 phones
when i roam between the WLCs i will lose the connection.
What should i configure on the WLC??
thx
migilles
Are you doing L3 mobility?
If so, would configure the voice ssid for the same VLAN on both controllers to see if that works or not.
Of course for mobility group setup, need the mac and IP configured on each contoller in that mobility group.
Ensure that 3.02 is loaded on the 7920 phones.
Would recommend 4.0.217.0 or later for the controller version.
Refer to WLAN SRND for more info.
http://www.cisco.com/univercd/cc/td/doc/solution/emblty30.pdf
General
802.3x Flow Control Mode
LWAPP Transport Mode
LAG Mode on next reboot
Ethernet Multicast Mode
Aggressive Load Balancing
Peer to Peer Blocking Mode
Over The Air Provisioning of AP
AP Fallback
Apple Talk Bridging
Fast SSID change
Default Mobility Domain Name
RF-Network Name
both WLCs are in the same mobility group.
Firmware on 7920: 7920.4.0-03-00
Firmware on WLCs: 4.0.217.0
thx
Would want to use 3.02 for 7920 as there were some key fixes in 3.01 to interoperate successfully with 4.0 controller version.
