09-11-2003 08:15 AM - edited 07-04-2021 09:00 AM
Can someone please explain to me the readout from the 7920 Site Survey tool? I'm taking guesses... I just hope I guessing right!
i.e.
1 (C), voice, 23, 0
6 (C), voice, 45, 3
11 (C), voice, 55,4
Solved! Go to Solution.
09-30-2003 02:57 PM
1= Channel
(C) = Connected
Voice= SSID
45= RSSI
0= Quality Param,
You may also see an (A), that means Available.
Scott
09-30-2003 02:57 PM
1= Channel
(C) = Connected
Voice= SSID
45= RSSI
0= Quality Param,
Scott
11-26-2003 02:35 PM
The RSSI should be at least 20 troughout the network to make calls and roam properly.
Tore
