Community Member
7920 v3.02 configuration errors
I'm getting the following error when connecting the configuration utility to the 7920: "Err 300 TFTP fails in importing configuration file." The phone firmware version is 7920.4.0-03-02 and the config utility is 3.02. Any ideas how to configure the 7920 that has the latest firmware? I tried going in and manually changing the profiles with no avail.
1 REPLY
Re: 7920 v3.02 configuration errors
Ensure you don't have another application using UDP port 69 (i.e. TFTP server).
Also disable any possible firewall.
160
