Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
7921 Connection Failed
i have a 7921 with app load id cp7921g-1.0.3.loads. The 7921 downloaded the configuring by tftp but soon it loses the wlan connection.
Now it is in connection failed status.
how to do for factory reset?
Any idea?
1 ACCEPTED SOLUTION
Re: 7921 Connection Failed
No, this is configured on an autonomous AP, but is really only mandatory if you have a -W model phone, which requires that 802.11d / world mode is enabled on the AP.
For losing connection, maybe could be BSS loss due to missing beacons or ACKs.
Would try 1.0.4 image, which is the latest.
http://www.cisco.com/cgi-bin/tablebuild.pl/ip-7900ser-crypto
#interface Dot11Radio0
world-mode dot11d country US both
Use this command and the countre is where manufactured
Hi Victor
The command should be entered in the IP Phone 7921, using the USB connection?
Cristian
Dear Michael
I have a 7921 Model CP=7921G-W-K9. Tomorrow i have to go to client and i will check this.
And if I'm getting this error of authentication at a LWAP with WLC 4402. How can I do? There is a command like that to insert at WLC??
Alexsandro Reimann
World mode (802.11d) is automatically enabled with the Cisco WLAN controller. When you choose the country (Wireless>Country) for which your APs have to match, then this also sets the country code for 802.11d.
Solved. Thanks a lot.
Thanks a lot....
This command resolve my problem with "Connection Failed" in IP Phone 7921G.
I use the firmware version 1.0.5 in my ip phone.
Thanks again!!!
To factory reset your 7921 ip phone, go to Settings>phone settings then press **2, it will display "start factory reset now" select yes and you are done.
Hope that helps.
Nnamdi
Hi, thank for you information.
1798
