7921 to 7921 no audio when on different controllers
** We have an intermittent issue with the 7921 to 7921 calls giving one way or no audio when call is answered
** CUCM 7.1.2.
** 7921 1.3.4 sr1
** The issue is when the users are connected to AP's on different controllers. Devices are on same VLAN.
** We are using a LWAPP 1142's on WISM's with 6.0.199.4 code
** The calls are connecting and we can see the packets being sent and received on the phone stream statistics on the CUCM page.
** Calls from 7925 to 7925, 7925 to 7921, lan line to 7921, cell phone to 7921, all work without issue. 7921 to 7921 on same controller works, but 7921 to 7921 on different controllers does not work.
1 ACCEPTED SOLUTION
ok, you may want to take a look at the latest firmware for the phones, 1.4.2.  You can load it on just two to test.
Steve
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
what encryptions/EAP are you using for the phones?
Steve
TKIP / EAP-FAST
Steve
We upgraded two phones to 1.42 and couldn't replicate the problem.  We're seeking approval to push the new code to all phones.
Thanks!
That's odd that 1.4(2) resolved the issue if the real issue was with inter-WLC roaming.
But 1.4(2) does have more aggressive scanning to ensure that the 792x phone has real-time neighbor list data and can roam to the next AP successfully, especially in a pico cell environment.
Anyways, glad it is working for you and yes 1.4(2) is the recommended version to use.
Re: 7921 to 7921 no audio when on different controllers
If the issue is with inter-WLC calls only, but intra-WLC calls work fine then wouldn't be a phone issue.
Would first check the WLAN config to see if the WLAN is using an interface in a different vlan as well the mobility group settings and switching/routing config on the wired side.
However yes it is recommend to use 1.4(2) for the 792x phones currently.
it wasn't roaming, just the phone being on a different WLC.  Would have made me think that the RTP stream wasn't making it, but the 7925 works across the WLC, only the 7921 didn't.  So that took the WLC out of the picture, at least until proven otherwise
Steve
That's weird.
Same scanning and roaming in 7921 and 7925 as well as SCCP and audio server implementation.
Probably more coincidence vs 7921 specific assuming that the 7921 was indeed associated and transmitted packets were making it upstream (AP Acking the frames) and the AP was forwarding the frames downstream correctly.
Anyways, this thread is marked as answered now and 1.4(2) is the right direction to take.
A simple test that I would do is to use two laptops  and mimic the issue. Run a continious ping from the 2 laptops towards each other. If the pings drop after inter controller you have an ARP issue. Use the following debug for the laptop that will be doing intercontroller roam.
>debug client
Do show  show mac addr on the core switch to see if the cam table is updated.
You can use the  same process for the Phone.
1098
