Community Member
7921G - Extended Battery is 100% charged but phone dies after 1 hour
One of my 7921G phone has an extended life battery. The battery is fully charged but dies after 1 hour of use. The battery icon on the LCD shows yellow at 25%. I have switched the battery to another working phone and it shows 100% charge. I have also reset to factory setting and this did not resolve the issue. I know it is not a battery issue and will like to know if the phone is defective or if there is a fix to be done. The 1 year warranty is up and the user does not want to pay for a new phone.
Re: 7921G - Extended Battery is 100% charged but phone dies afte
It sounds like a phone issue, if they are both running the same software. Appears the battery is calibrated.
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/7921g/firmware/1_1/english/release/notes/7921_11.html#wp193242
If the customer does not have a SmartNet contract and the warranty is up, then not much can be done except replace it.
Community Member
Thanks for the information, I have verified the battery is calibrated correctly. I do have a Smartnet contract with Cisco via IBM. Does this mean I can have the phone replaced at no cost?
I suggest you call TAC to check entitlement of the phone.
Community Member
How far away are your APs? The farther the AP is from the wireless phone the more power it takes.
I had a customer whose 7921s were eating battery power too fast. We added additional APs and now the batteries are lasting a lot longer.
Community Member
Thanks all for your help. Cisco has replaced the wireless phone and this has resolved the issue.
398
