12-07-2007 09:55 AM - edited 07-03-2021 03:04 PM
We are having issues with calls getting dropped when a 7921G phone traverses from a WAP that is connected to Wireless LAN Controller A and transfers to a WAP on Wireless LAN Controller B. This is occurring with both of our 4402WLC and 2106 WLC. We have mobility groups enabled and setup and they can ping the other controllers. There is no problems when traversing from one WAP to another WAP that are associated with the same WLC controller. Any ideas where the problem may be?? I'm trying to find information on configuration settings for this but not much information out there.
Solved! Go to Solution.
12-13-2007 10:52 AM
The firmware upgrade going from 1.02 to 1.04 did not fix the problem. What actually fixed the problem was VLANs on the port channel between the cores on the network. Verify that on the WLC that LAG mode is also enabled.
12-13-2007 01:01 PM
I'm still not sure what happened...were there different Vlans on different trunks?
12-16-2007 09:21 AM
What actually fixed the problem was VLANs on the port channel between the cores on the network. I verify that on the WLC that LAG mode is also enabled.
12-14-2007 05:49 PM
Have you ticked the 'Enable Fast SSID Change' option on the WLC under the Controller page?
Richard.
