Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
7921G SIP Calls only
Is there a specific firmware to enable the port assignments for the SIP usage? Is there a way to configure the phone without using the call manager?
Re: 7921G SIP Calls only
No, the 7921/7925 doesn't support SIP at this time. So must use SCCP, which requires CM.
Are the SIP Dual-tone options which are the advanced features of the 7921G the same for SIP calls?
851
