7925g Network Busy
mark
I have a problem with connecting multiple 7925gs connecting to a single Aironet 1131.  I have setup two vlans, vlan 1 and 100.  Vlan 1 has about 4 devices and works like a charm, on the voice vlan, when using one phone it works fine but when I connect the second phone, it says network busy.  I don't know what I am missing.  Below is the AP config.  Thanks for the help.
version 12.4
no service pad
service password-encryption
hostname ap
logging rate-limit console 9
enable secret 5 $1$0gRq$aVHzQCQkao.eIbOaLrZgs.
no aaa new-model
dot11 syslog
dot11 ssid OLMOSVOICE
   vlan 100
   authentication open
         dot11 ssid Olmos
   vlan 1
   max-associations 25
   authentication open
   authentication key-management wpa
   guest-mode
   wpa-psk ascii 7 111A1A0D001319181E
username Cisco password 7 01300F175804
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers tkip
encryption vlan 1 mode ciphers tkip
encryption vlan 100 key 1 size 128bit 7 C3B20D08215A7CB17D2E4A7A3F6C transmit-key
encryption vlan 100 mode wep mandatory
ssid OLMOSVOICE
ssid Olmos
speed  basic-1.0 2.0 5.5 11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.100
encapsulation dot1Q 100
no ip route-cache
bridge-group 100
bridge-group 100 subscriber-loop-control
bridge-group 100 block-unknown-source
no bridge-group 100 source-learning
no bridge-group 100 unicast-flooding
bridge-group 100 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
interface FastEthernet0.1
no ip route-cache
bridge-group 1
interface FastEthernet0.100
no ip route-cache
bridge-group 100
interface BVI1
ip address dhcp client-id FastEthernet0
no ip route-cache
ip http server
no ip http secure-server
ip http help-path
http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
Network Busy is due to CAC or a misconfig not authentication or encryption.
Since this is autonomous, ensure you add "admit-traffic" under the ssid.
You don't need to add this in the later IOS versions.
You may want to check your version and upgrade if not updated already.
The 792x phone will send a TSPEC for signaling (UP4) regardless if ACM is enabled for video queue.
See page 62 of the 7925G Deployment Guide.
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/7925g/7_0/english/deployment/guide/7925dply.pdf
Example below:
   vlan 100
   authentication open
   admit-traffic
You may want to look through the rest of the guide to optimize the AP config.
May want to consider WPA2-PSK leveraging AES vs open+WEP as well.
Also if you enable proxy ARP (dot11 arp-cache optional) you will get optimal idle battery life.   See page 66.
Justin Kurynny
Level 4
Level 4
Mark,
Try associating the phones with the encryption off the SSID (open, no WEP).
Also, do you always try to associate the phones in the same order (e.g., Phone A then Phone B)? If you haven't done this already, try the second phone first and then add the first phone second to see if the problem follows the phone or follows the order of association.
Justin
Example below:
   vlan 100
   authentication open
   admit-traffic
migilles,
Great information, thanks for posting the explanation and example.
Justin
Looks like the admit traffic command resolved the issue.
Thank you
