7925G wireless regulatory domain
I want to order Cisco Wireless 7925G IP Phone in INDIA. Which is the correct part code which needs to be ordered.
Re: 7925G wireless regulatory domain
You will want to order the -W model (CP-7925G-W-K9).
VIP Purple
HI Gautam,
You must order CP-7925G-W-K9.
Dont forget to rate helpful posts.
Bronze
Hi,You are from india so you
You are from india so you must order CP-7925G-W-K9
979
