7926G works over 802.11g but not 802.11a
                   We have a 1600 AP and can regsiter phones fine over a 802.11g. But when using the 802.11a it never gets connected and the phones signal light is blinking with yellow flag off/on. Other laptops though connect to the AP on 802.11a. What could be the problem? and /or where to start?
Is the AP1600 in unified or autonomous mode?
802.11d (world mode) is required when using 5 GHz (802.11a) as only a single model for 7926G is offered to all around the world.
For 2.4 GHz, channels 1-11 can be scanned as those channels are common around the world.
802.11d  is enabled by default for a unified AP when registered to a Cisco WLC,  but it is not enabled by default for an autonomous AP.
So if using autonomous AP, ensure you enable the country code.
See the 7925/7926 Deployment Guide for supported country codes.
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/7925g/7_0/english/deployment/guide/7925dply.pdf
Bronze
Hi,please make sure you have
please make sure you have checked all the data rates in the AP for 802.11a 5GHz band and aslo selected non-overlaping channel at you AP.
759
