AIR-LAP-1231G-A-K9 Problem with light weight commands on access point
Hi All
I got a issue with AP 1231g it wont take any Light weight commands after I conected to the controller any help is good....
I reset the item too default same issue....  in about 10 AP.
thanks guys
sincerely
JC
George Stefanick
What commands are you attempting to use ?
Leo Laohoo
If you are using 4.X and 5.X firmware, there are a lot of LWAP commands that are disabled.
Thanks  I will ask more details,   I already ask that question to the customer.
but no answer back.....yet...
thanks a lot for you time too....
keep in touch.
cmartin_39
There is little need to access the AP in lwapp mode unless you are manually priming or troubleshooting ...
