Aironet 1040 Serien, Can limit users in SSID?
Alex Alvarez
Some time ago have this question, and now is a problem, because a ssid have more users than workstations!
Anyone little help?¡
2 Accepted Solutions
Sandeep Choudhary
Do you have this AP in autonomous mode or Lightweight mode ???
If you this as Lightweight then you can restrict client per WLAN:
Here is the procedure:
http://www.cisco.com/en/US/products/ps6366/products_configuration_example09186a0080b9c159.shtml
If Autonomous then:
1st method: I am not sure about this method:
You can limit per SSID:
AP(config-ssid)# max-associations 20
The above example allows for 20 clients only to connect to the SSID. Change the number as you need.
2nd:
You can use mac filter.
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a0080c1e40b.shtml
Dont forget to rate helpful posts
kaaftab
Level 4
Level 4
You can use the command
 AP#max-association
http://www.cisco.com/c/en/us/td/docs/wireless/access_point/12-2_13_JA/configuration/guide/i12213sc/s13ssid.html
to limit the users but do the capacity planning before limiting the users
Sandeep Choudhary
If Autonomous then:
2nd:
kaaftab
Level 4
Level 4
 AP#max-association
Abha Jha
posted below answer :-
The below link gives you idea about max allowed clients and also how to limit the maximum clients per WLAN.
You wil have to go to advanced tab of WLAN on WLC and enter the number of maximum clients that can be connected to the given WLAN.
http://www.cisco.com/image/gif/paws/113303/restrict-wlan-clients-00.pdf
