Community Member
Aironet 1250 channel bonding - config 802.11a chan_width
Hi ,
I tried to bond two 20MHz channels on a 1250 (802.11A - LWAPP - 12.4(10b)JA) but get the following error:
' Slot is not Disabled or Customize is not enabled'
I have disabled the 802.11network/ radios etcetc but no luck yet.
Reg
Goen
Silver
Re: Aironet 1250 channel bonding - config 802.11a chan_width
You can not club to channels for usage with wireless network. You only have an option to add a channel available to be allocated. You use the command config 802.11 channel ap for this purpose.
Community Member
I am having the same issue while in LWAP mode.
According to this document:
http://www.cisco.com/en/US/solutions/collateral/ns340/ns394/ns348/ns767/white_paper_80211n_design_and_deployment_guidelines.html
40mhz is supported on WLC's, it even gives steps on how to enable it, but I am receiving the same error as the original poster.
I was able to successfully deploy 802.11n @ 40mhz in autonomous mode, but the operation fails in LWAP mode.
I am going to open a TAC case to see if this is a bug.
Jeremy
Hall of Fame Super Silver
You have to set the channel first then change the channel width. You might have to set the power also...
If you want to set above 40MHz use these channels: 36,44,52,60,100,108,116,132,149.157
If you want to set below 40MHz use these channels: 40,48,56,64,104,112,136,153,161
Hope this helps.
-Scott
Community Member
Hi Jeremy, I see your post is
Hi Jeremy, I see your post is very old but I wanted to reply in case Cisco TAC was able to solve your issue and ask if you know of a way to set the Channel Width with Templates or CLI.
Ed
VIP Purple
Hi Ed,Did you try something
Hi Ed,
Did you try something like below. Replace your AP name with LAP1 below.
(5508-1) >config 802.11a disable LAP1
(5508-1) >config 802.11a chan_width LAP1 40
(5508-1) >config 802.11a enable LAP1
(5508-1) >save config
Are you sure you want to save? (y/n) y
Rasika
**** Pls rate all useful responses ****
Community Member
The AP I was testing was on
The AP I was testing was on the wrong channel for 40mhz width.
THANKS
Community Member
Thanks man !It worked for me
Thanks man !
It worked for me ;)
I am sorry to say that you
I am sorry to say that you cannot mix the channel 20MHz channels on a 1250 (802.11A - LWAPP - 12.4(10b)JA)
Bronze
Yes i tested. Try this from
Yes i tested.
Try this from Controller console.
First disable the 802.11a then mention the below commands for your LAP.
save config
hope this will work.
Note: If problem persist ,reimage the lap and try again.
2150
