I want to permit from a user profile with the telnet CLI command to configure the new MAC address on the dot11 association mac-list 700
I have create the user 14 with the followed commands:
enable secret level 14 5 **************
enable secret 5 **************
privilege configure level 14 access-list
privilege exec level 14 write memory
privilege exec level 14 configure terminal
privilege exec level 14 show dot11 associations client
privilege exec level 14 show access-lists
Access from login privilege 14
1602AP16#show privile
Current privilege level is 14
1602AP16#show access-l
Bridge address access list 700
permit 100b.a965.7384 0000.0000.0000 (2 matches)
permit 0026.c659.b182 0000.0000.0000
permit 0019.d2c2.96c0 0000.0000.0000
OK
add the new MAC address
1602AP16(config)#access-list ?
<1-99> IP standard access list
<100-199> IP extended access list
<1100-1199> Extended 48-bit MAC address access list
<1300-1999> IP standard access list (expanded range)
<200-299> Protocol type-code access list
<2000-2699> IP extended access list (expanded range)
<700-799> 48-bit MAC address access list
1602AP16(config)#access-list 700 permit 0026.c659.b182 0000.0000.0000
% Invalid input detected at '^' marker.
I can open the user level 14 config and when I add the new MAC address I received the " Invalid input detected " message
What is wrong ?
Is it only permit at level 15 ?
IOS version :
Cisco IOS Software, C1600 Software (AP1G2-K9W7-M), Version 15.2(2)JB, RELEASE SOFTWARE (fc1)
Thank you to shared me yours comments !
Patrick
