Aironet 350 Bridge
Can you configure Bridge to work in a full duplex mode?
  • Wireless IP Voice and Video
Re: Aironet 350 Bridge
You can't have full duplex because both ends of a bridge link transmit on the same center frequency.
In short no. Another problem is with only antenna, the radio cannot transmit and receive at the same time on the same radio frequency.
Thanks alot..
Go with an FSO solution (much higher bandwidth, and you can have full duplex)
... or gang 2 or 3 350s together and load balance.
each one will still be half-duplex, but the potential for 2 or 3 to be tied up transmitting without receiving at the same time will be reduced.
Plus the aggregate pipe is 22 or 33Mbps nominal.
Do you know if you can deploy Netmeetings H.323 based VoIP over the 350 bridge??
Jon
193
