AP damaged?? how to test it?
Hello guys,
I have a AP AIR-AP1242G-A-k9, It seems that a voltage variation damaged it, noww I´m tring to enter to the GUI(using a straight cable), but ethernet´s led is off, it seems that the slot rj-45 is damaged cause it doesnt turn green on, Status LED is steady green and checking the reference guide I didn´t find help. How can I check if the hardware of the AP is ok?? what is the meaning of ethernet off, radio off and status steady green?? why i connect the utp cable from network (with dynamic dhcp service running (tested)) to the AP the ethernet led doesn´t turn on?? these symtoms mean the AP is damaged??
Note: these are some things that I did:
Confurate a static ip address in the ethernet interface and connect it to the PC (pc inside the same segment of network)
Reset to default settings using MODE button and erasasing the startup config file from Console
check the Reference guides.
Thank you 4 your attention!
Jerry
1 ACCEPTED SOLUTION
Re: AP damaged?? how to test it?
Have you tried updating the firmware via the console?
__________________________________________________________________________________________ "Satisfaction does not come from knowing the solution, it comes from knowing why." - Rosalind Franklin ___________________________________________________________
Maybe this can help you to help me:
ap#reload
Proceed with reload? [confirm]
*Mar  1 00:02:55.386: %SYS-5-RELOAD: Reload requested by console.
Reload Reason: Reload Command.Xmodem file system is available.
flashfs[0]: 147 files,
7 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]:
Total bytes: 15998976
flashfs[0]: Bytes used: 5479936
flashfs[0]:
Bytes available: 10519040
flashfs[0]: flashfs fsck took 27 seconds.
Base ethernet MAC Address:
00:22:90:1b:c6:98
Initializing ethernet port 0...
Reset ethernet port 0...
Reset done!
link auto-negotiating....
auto-negotiation takes 10000 milli-seconds to complete
ERROR: timeout waiting for auto-negotiation to complete
ERROR: fail to bring ethernet link up
The system has been encountered an error initializing
ethernet port.
You may need to check hardware
The system is ignoring the error and continuing boot.
If you interrupt the system boot process, the following
commands will reinitialize ethernet,
tftp, and finish
loading the operating system software:
    ether_init
    tftp_init
    boot
Loading "flash:/c1240-k9w7-mx.124-10b.JA/c1240-k9w7-mx.124-10b.JA"...##########################################
File "flash:/c1240-k9w7-mx.124-10b.JA/c1240-k9w7-mx.124-10b.JA" uncompressed and installed,
entry point: 0x3000
executing...
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, C1240 Software (C1240-K9W7-M), Version 12.4(10b)JA, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Wed 24-Oct-07 15:31 by prod_rel_team
Image text-base: 0x00003000, data-base: 0x00859060
Initializing flashfs...
flashfs[1]: 147 files, 7 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 15998976
flashfs[1]: Bytes used: 5479936
flashfs[1]: Bytes available: 10519040
flashfs[1]: flashfs fsck took 4 seconds.
flashfs[1]: Initialization complete....done Initializing flashfs.
Radio 1 A506 7100 E8000000 A0000000 80000000 3
Radio 0 0 0 0 0 0 2
A summary of U.S. laws governing Cisco cryptographic products may be found at:
http://www.cisco.com/wwl/export/crypto/tool/stqrg.html you require further assistance please contact us by sending email to
export@cisco.com. AIR-AP1242G-A-K9     (PowerPCElvis) processor (revision A0) with 24566K/8192K bytes of memory.
Processor board ID FTX1244B7BB
PowerPCElvis CPU at 262Mhz, revision number 0x0950
Last reset from reload
1 FastEthernet interface
1 802.11 Radio(s)
If
cisco
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:22:90:1B:C6:98
Part Number                          : 73-11465-01
PCA Assembly Number                  : 800-30492-01
PCA Revision Number                  : A0
PCB Serial Number                    : FOC12415D6W
Top Assembly Part Number             : 800-29585-03
Top Assembly Serial Number           : FTX1244B7BB
Top Revision Number                  : A0
Product/Model Number                 : AIR-AP1242G-A-K9
o
% Invalid input detected at '^' marker.
Press RETURN to get started
Did it work?
well, in fact I don´t know how to updagrade the IOS since it doesn´t work the ethernet port, I know that it is possible upgrade the IOS using the Console cable working with router and switches,  but I could´t find how to do it using an AP. If you could ponit to me, Than you George
do you know any command(s) to test the Hardware, specially the ethernet port??
This is the part that I don´t like :
The system has been encountered an error initializing ethernet port.
You may need to check hardware. The system is ignoring the error and continuing boot.
I conclude that I have to make valid the warranty, Im correct??
Hall of Fame Super Gold
You can upgrade the firmware via console using XModem.
Xmodem Console Download Procedure Using ROMmon
http://www.cisco.com/en/US/customer/products/hw/routers/ps259/products_tech_note09186a008015bfac.shtml
999
