Ap1100 and QoS
We have a customer with about 40 AP1100 and without wireless controller.
These AP's are used only for voice. The customer use 7920 cisco phones.
Sometimes the customer experience some blank gap in the voice.
On the AP's the QoS is not implemented because there is only voice traffic.
Is it correct not to implement QoS on AP's? Or, even if there is only voice traffic, the QoS on AP's should be implemented?
Re: Ap1100 and QoS
I am not a voice wizzard, but i would want to run QoS on the AP's as for an exact reason why...well since voice usualy requires a fixed bit rate. QoS will manage Bandwidth, latency, jitter, and reliability. thus allowing your existing network to run more efficently, and better performance. Hope this helps.
Re: Ap1100 and QoS
Would ensure that you use 12.3(8)JEA1 on the AP and 3.02 on the 7920.
Does this gap occur when roaming? Not per say physically moving, but AP reassociating to a different AP.
Yes QoS should be implemented, but AP uses CDP to detect 7920 to put it's packets into voice queue. Below is a sample QoS policy to enable if DSCP is preserved. Then apply these to the interfaces.
class-map match-all SCCP
match ip dscp cs3
class-map match-all RTP
match ip dscp ef
policy-map Voice
class RTP
set cos 6
class SCCP
set cos 3
Re: Ap1100 and QoS
Hi thanks a lot for your answers.
Yes the gap occurs when roaming. The software versions of AP's and 7920 are a little bit older so I will provide and update and let you know the result.
Where should I apply the config? On the switch side or AP side? With service policy input or service policy output?
180
