AP121 Clients losing connection
Hello all,
At our home/ office we have four AP121 clustered together as one. Every now and then our connected clients (iphone, ipad, macbook, windows tablets and laptops, …) loose the connection with the wireless and then we have to reconnect again.
This is getting a bit tiresome and so I've decided to try and fix this, but I cannot find the fault myself. So I'm asking help :)
Thank you in advance!
Our setup is as follows:
Broadband modem -> Cisco 1941 router -> SG300-28 -> SG300-24P -> AP's 1-4
Update: Here is the configuration
Router config
ip dhcp pool data
 network 10.0.90.0 255.255.255.192
 dns-server 10.0.0.2 10.0.0.3
 default-router 10.0.90.1
 domain-name gregoir.local
 lease 0 1
ip dhcp pool wireless-guest
 network 192.168.1.0 255.255.255.192
 dns-server 8.8.8.8 8.8.4.4
 default-router 192.168.1.1
 domain-name gregoir-guest.local
 lease 0 1
ip domain list gregoir.local
ip domain name gregoir.local
ip name-server 10.0.0.2
ip name-server 10.0.0.3
ip cef
no ipv6 cef
interface GigabitEthernet0/1.50
 description WIRELESS VLAN$ETH-LAN$$FW_INSIDE$
 encapsulation dot1Q 50
 ip address 10.0.50.1 255.255.255.192
 ip nat inside
 ip virtual-reassembly in
interface GigabitEthernet0/1.90
 description DATA VLAN$ETH-LAN$$FW_INSIDE$
 encapsulation dot1Q 90
 ip address 10.0.90.1 255.255.255.192
 ip nat inside
ip access-list extended guest-internet
 deny   ip 192.168.1.0 0.0.0.255 10.0.0.0 0.0.0.63
 deny   ip 192.168.1.0 0.0.0.255 10.0.10.0 0.0.0.63
 deny   ip 192.168.1.0 0.0.0.255 10.0.30.0 0.0.0.63
 deny   ip 192.168.1.0 0.0.0.255 10.0.50.0 0.0.0.63
 deny   ip 192.168.1.0 0.0.0.255 10.0.70.0 0.0.0.63
 deny   ip 192.168.1.0 0.0.0.255 10.0.90.0 0.0.0.63
 deny   ip any 10.0.0.0 0.0.0.63
 deny   ip any 10.0.10.0 0.0.0.63
 deny   ip any 10.0.30.0 0.0.0.63
 deny   ip any 10.0.50.0 0.0.0.63
 deny   ip any 10.0.70.0 0.0.0.63
 deny   ip any 10.0.90.0 0.0.0.63
 permit ip any any log
SWITCH 1: SG300-28
interface vlan 50
 name wireless
 ip dhcp relay enable
interface vlan 90
 name data
interface gigabitethernet25
 no negotiation
 description "GI25 -> C1941RTR"
 spanning-tree link-type point-to-point
 spanning-tree bpduguard enable
 switchport trunk allowed vlan add 10,25,30,50,70,90
 macro description switch
 !next command is internal.
 macro auto smartport dynamic_type switch
interface Port-channel1
 description "SG300-28 -> SF300-24P"
SWITCH 2: SG300-24P
interface vlan 50
 name Wireless
interface vlan 90
 name Data
interface range fastethernet1-4
 switchport trunk allowed vlan add 25
 switchport trunk native vlan 90
1 REPLY
Problem seems to be fixed.
For those interested it where the channels of the radio that needed reconfiguring (too much interference from other AP's).
115
