B/G vs. N an APs
At work (as a first call responder)  I am troubleshooting choppy video feeds over wireless, and while I am not big into wireless knowledge, my question is if we have an AP (Merus) which can handle A and B/G and N...if we have clients connected to B/G and/or A, then do the N clients still connect at N speeds (to the same AP) or do they dumb down their connection speeds to match that of the lowest connecting client?
Very far back in my memory I seem to remember something like this, but am not sure.
Thank you
3 ACCEPTED SOLUTIONS
Hall of Fame Super Silver
Re: B/G vs. N an APs
I guess you can say "dumb down":) the radio has to play nice in order for the slower devices to be able to communicate. The main issue is the half duplex and the back off timers. Here is a good link, look under share bandwidth.
http://its.uiowa.edu/apps2/support/article/2168
Scott Fella
Sent from my iPhone
-Scott
B/G vs. N an APs
Typically, they will keep there own connection rates.  The problem is that the 'faster' clients have to wait for the 'slower' clients to finish transmitting before they can send.
Make sense?
Steve
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
Like Steve mentioned, you will not see slower connection rate, but they will have to slow down for the slower users.
Scott Fella
Sent from my iPhone
-Scott
Scott Fella
Sent from my iPhone
-Scott
B/G vs. N an APs
Make sense?
Steve
Yes, wow, quick response, ty, so it will defintely impact their throughput rates.
Say a N client connected to an say AP1 (with dual band A, B/G, N capabilities), all by himself, it should see good rates.
Now, lets say a 1 A client and 1 B client connect to the same AP1, will the N client thoughput see slower rates exclusively based solely on these clients connecting?
Thank you,
Scott Fella
Sent from my iPhone
-Scott
Aye aye, thanks all.
Update:    I suggested that they turn B/G off and use N exclusively in this schools lab, that worked.
Message was edited by: Jimmy Sands
804
