backplane and throghput in wlc 4402
hi,
what is the back plane and through put of wlc 4402 ,is there any backplane and throughput 1131 series wireless device,
2. what is difference between data rate and bandwidth, i mean 54mbps signifies in wireless datarate or its bandwidth per ap 1131
1 REPLY
Re: backplane and throghput in wlc 4402
The throughput of the 4402 is up to 2Gbps if its ports are bundled in a etherchannel.
For access points, data rate is the speed at which the data frame is transmitted. to evaluate throughput you must add the fact that the medium is half-duplex, that there is signaling overhead and that there are moments of silence.
Overall, the throughput for a 11g access points (1130,1240) is 19Mbps. This is what you test in real life with iperf.
Nicolas
476
