Cisco 7921 - Spectrum management is not enabled/supported by AP.
Hi all :)
I get the following alarm from the site survey on a 7921.
Can anyone tell me what this means?
Also, when you are walking around doing a site survey, what is the CU?
Many thx indeed,
Ken
1 ACCEPTED SOLUTION
Re: Cisco 7921 - Spectrum management is not enabled/supported by
This is referring to 802.11h when using 5 GHz.
I assume this is the Cisco Unified Wireless LAN Controller?
If so, check to ensure that Channel Announcement and Channel Quiet Mode are enabled
See page 44 in the 7921G Deployment Guide @ http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/7921g/6_0/english/deployment/guide/7921dply.pdf')">http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/7921g/6_0/english/deployment/guide/7921dply.pdf.
CU stands for Channel Utilization, which is based on QBSS information provided by the AP to inform the client how busy the channel is.
Hall of Fame Super Gold
What's the model of your AP and the WLC's firmware?
Brill. Have ready this and made the amandements. Many thx for your help.
Kind regards,
Ken
283
