08-07-2008 04:38 AM - edited 07-03-2021 04:17 PM
Hi Guys,
I have just received a 7921 and have no idea how to use it. So looking at the documentation, these phones will only work if connected to Cisco call manager correct?
If I cant gain access to a call manager at the moment, can I use the phone as a wireless device? ie, connect to a SSID like starbucks, and connect to the web for browsing?
If not, I will just put it back in my drawer
Thx
Ken
Solved! Go to Solution.
08-07-2008 04:53 AM
Hi Ken,
The 7921G is is proprietary Cisco device and must be connected to either a Cisco Callmanager or Callmanager Express :( You won't be able to use it outside of your enterprise.
Really a pretty great phone though, we are just labbing up our first few.
Hope this helps!
Rob
08-07-2008 04:53 AM
Hi Ken,
Hope this helps!
Rob
08-07-2008 05:00 AM
Thats a shame :(
Thanks Rob anyway
I was just hoping to use some of the site survey tools that are supposed on the phone, but cant do nowt without it connecting to a CM
shame :(
Ta fella,
Ken
08-07-2008 05:31 AM
Hi Ken,
I'm sorry, I must have misunderstood your question :( You can use the 7921 Site Survey function without being Registered to Callmanager. I was referring to actual "Calling "features. Have a look;
Hope this helps!
Rob
PS: I like the way your VoWLAN document is shaping up. Looks good!
08-07-2008 05:34 AM
thanks fella, I will get a generic design rules doco out and post it for all :) We can all add comments to it :)
Many thx, will look at the link now.
Ur a top man !!!
08-13-2008 06:32 PM
The 7921G Deployment Guide is posted @ http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/7921g/6_0/english/deployment/guide/7921dply.pdf.
