Cisco 871 Wireless config can't get dhcp address
I have an Cisco 871 router configured to connect back to my home office.  I can get a DHCP address when connected wired through the FE0 interface.  However, I cannot get an IP address through wireless.  I need to get an ip address in vlan 101 in the 10.38.201 subnet.  Here is the relavant config.  I have also attached the full config.
dot11 ssid nexusis
vlan 101
authentication open
authentication key-management wpa
guest-mode
wpa-psk ascii 7 06575D72181B5F4E5D
ip dhcp smart-relay
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.1.201 192.168.1.254
ip dhcp excluded-address 192.168.1.1 192.168.1.104
ip dhcp excluded-address 192.168.1.1 192.168.1.99
ip dhcp excluded-address 10.38.201.10 10.38.201.12
ip dhcp pool wireless
   network 10.38.201.16 255.255.255.240
   default-router 10.38.201.17
   option 150 ip 10.38.32.8
   dns-server 10.38.16.32
   domain-name nexusis.com
bridge irb
interface Loopback0
ip address 10.38.14.30 255.255.255.255
interface Tunnel0
bandwidth 1000
ip address 10.38.200.3 255.255.255.128
no ip redirects
ip mtu 1400
ip nhrp authentication DMVPN_NW
ip nhrp map 10.38.200.125 64.138.140.21
ip nhrp map multicast 64.138.140.21
ip nhrp network-id 100000
ip nhrp holdtime 360
ip nhrp nhs 10.38.200.125
ip tcp adjust-mss 1360
ip ospf network broadcast
ip ospf hello-interval 30
--More--                            ip ospf priority 0
delay 1000
qos pre-classify
tunnel source FastEthernet4
tunnel mode gre multipoint
tunnel key 100000
tunnel protection ipsec profile SDM_Profile1
interface Null0
no ip unreachables
interface FastEthernet0
switchport trunk native vlan 101
switchport mode trunk
switchport voice vlan 101
spanning-tree portfast
interface FastEthernet1
interface FastEthernet2
--More--                            switchport voice vlan 101
interface FastEthernet3
interface FastEthernet4
description $FW_OUTSIDE$$ES_WAN$
ip address dhcp client-id FastEthernet4
ip access-group 101 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nbar protocol-discovery
ip flow ingress
ip nat outside
ip ips sdm_ips_rule in
ip inspect DEFAULT100 out
ip virtual-reassembly
ip ospf cost 100
duplex auto
speed auto
no cdp enable
--More--                            service-policy output SDM-Pol-FastEthernet4
interface Dot11Radio0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip flow egress
encryption mode ciphers aes-ccm
encryption vlan 101 mode ciphers aes-ccm
ssid nexusis
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
channel 2462
station-role root
no cdp enable
--More--                           interface Dot11Radio0.101
encapsulation dot1Q 101 native
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$FW_INSIDE$
no ip address
bridge-group 1
interface Vlan101
ip address 10.38.201.17 255.255.255.240
interface Dialer0
no ip address
interface BVI1
description $ES_LAN$$FW_INSIDE$
--More--                            ip address 192.168.2.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
ip ips sdm_ips_rule out
ip tcp adjust-mss 1452
bridge 1 protocol ieee
bridge 1 route ip
Bronze
Please check the below link for Step by Stey   DHCP Configuration in WLC-871
http://www.piglet-net.net/tech/cisco/cisco-871W-simple.html
Re: Cisco 871 Wireless config can't get dhcp address
So bridge group 1 is tied to BVi1, not vlan 101.
Since the DHCP scope isn't for BVI1, you won't get an IP address.
I would set a different bridge group # for dot11radio 0.101 and then put that bridge group on vlan 101 as well.
I'd move the IP address from the VLAN 101 interface to the BVI 1 interface, and then add bridge-group 1 under the VLAN
basicaly
interface Vlan101
no ip address
bridge-group 1
Interface BVI 1
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
Kindly find the link below to configure DHCP steps and even the VLAN configuration.
http://www.cisco.com/en/US/docs/routers/access/800/850/software/configuration/guide/dhcpvlan.html#wpxref42306
Silver
Kindly check the following link for wifi deployment(template)
                        https://supportforums.cisco.com/docs/DOC-16087
interface Vlan101 and interface Dot11Radio0.101 both should be mappped to the same bridge group.
2737
